NEW MCLAREN 788HS: THE PINNACLE OF AN ERA-DEFINING SERIES OF SUPERCARS
Introducing the McLaren 788HS – the definitive and final evolution of the award-winning McLaren 720S, 750S and 765LT supercar series
‘High Sport’ delivers 788PS from its 4.0-litre V8 twin-turbocharged engine
Advanced aero package, in all carbon fibre, features a multi-zone front splitter, bonnet with S-duct, raised active rear spoiler and racing-inspired diffuser
Every example made unique through McLaren Special Operations (MSO)
Production is limited to 200 vehicles globally, with equal split across coupe and spider variants
McLaren introduces the new 788HS – the definitive and final evolution of its award-winning series supercar that celebrates and concludes the multi-award-winning supercar lineage that began with 720S and evolved through 765LT and 750S.
The 788HS features a 788PS 4.0-litre twin turbo V8, which combines with a 1,265kg dry weight to deliver a power-to-weight of 623PS per tonne – the highest achieved by any model in the 720S, 750S and 765LT series. When coupled with the unique aerodynamic package, amplified exterior design cues and personalisation possibilities, the result is heightened performance on track, even greater engagement on the road, and the chance for each client to celebrate the car’s era-defining linage in their own way using the expertise of McLaren Special Operations (MSO).
The McLaren 788HS wears the ‘High Sport’ designation reserved only for the most special expressions of a series production McLaren. Until now, this rare badge has only appeared on two previous McLarens; the MP4-12C HS and the MSO HS.
“The new McLaren 788HS has been designed and engineered with a singular focus; to deliver a visceral experience and captivating drive through its precise balance of performance, sound, dynamism and individuality. It represents the ultimate expression of our supercar series that began with the 720S and becomes only the third McLaren to wear our HS designation – a fitting finale for a much loved and critically acclaimed car.”
Henrik Wilhelmsmeyer, Chief Commercial Officer, McLaren Automotive
Assertive design
The McLaren 788HS features sculpted bodywork elements that provide the most advanced aerodynamic package ever applied to the platform, increasing downforce by 10% over 765LT, with uncompromised vehicle dynamics and balance.
The aerodynamic concept centres around a new S-Duct bonnet, a raised active rear spoiler and an intricate Formula 1-inspired rear diffuser. Working in combination with a bespoke front splitter, these elements enhance stability, performance and driver confidence. The louvred under-wing panel further supports powertrain cooling and aerodynamic efficiency.
Gloss black exterior accents include a roof scoop on Coupe derivatives, and clients can opt for full Visual Carbon Fibre bodywork – encompassing every exterior panel – highlighting the car’s lightweight construction.
The driver centric cabin layout includes a lightweight carbon fibre centre console that signifies the level of focus applied to every aspect of 788HS.
The cabin also features bespoke HS branding with a unique perforation pattern for the upholstery and a dedication plaque.
Track precision meets on-road engagement
The heart of the 788HS is McLaren’s M840T 4.0-litre twin-turbo V8, which revs to 8,500rpm and develops peak power at 7,500rpm. With 800Nm of torque it delivers immediate response and sustained acceleration – from 0-100km/h in 2.8s, 0-200km/h in 7.0s, to a top speed of 330km/h (205mph). A unique engine mount calibration for 788HS delivers heightened engagement and connection between powertrain and driver without compromising long-distance usability.
Proactive Chassis Control III linked-hydraulic suspension system with bespoke suspension tuning delivers even higher levels of dynamic performance. The 788HS also features a 5mm lower front ride height than the 750S, for a more dynamic and engaging driving experience.
Braking performance is enhanced through carbon ceramic discs derived from the McLaren Senna, with black six-piston forged aluminium monoblock front calipers and integrated cooling for sustained high-performance use. The 788HS also introduces the first centre-lock wheel mechanism ever fitted to this supercar series, in combination with a new Super Lightweight Forged Alloy wheel.
The quad-exit titanium exhaust system amplifies the V8’s distinctive soundtrack, with more intensity throughout the rev range, while carefully engineered induction and exhaust sound symposer technologies immerse occupants in the unmistakable soundtrack of McLaren’s twin-turbocharged V8.
______________
Ends
Technical Highlights of 788HS
Powertrain
4.0-litre M840T twin-turbocharged V8 engine
Lightweight forged pistons
Ultra-low inertia twin scroll turbochargers
Twin fuel pumps
Peak power output of 788PS (777bhp) at 7,500rpm
Peak torque of 800Nm (590lb ft) at 5,500rpm
Lightweight engineering
Carbon fibre monocoque chassis
High-performance, lightweight materials throughout with advanced carbon fibre technologies for body components
New HS aerodynamic package, all in carbon fibre
Lightweight interior components
Dry weight of 1,265kg
Power to weight ratio of 623PS per tonne, the highest in this supercar series
Optional full visual carbon fibre body available in gloss or satin finishes
Aerodynamics
Multi-zone front splitter
S-Duct bonnet
Raised active rear spoiler
Louvred under wing panel
Formula 1-inspired diffuser with 10% increase in downforce compared with McLaren 765LT
Chassis and suspension
Linked-hydraulic Proactive Chassis Control III suspension system
Bespoke suspension calibration
Adaptive dampers
Front ride height lowered by 5mm versus 750S
Enhanced body control, precision and responsiveness
Braking system
Carbon ceramic brake discs derived from McLaren Senna
Six piston forged aluminum monoblock front calipers
Racing inspired integrated brake caliper cooling ducts
Enhanced pedal feel and stopping performance
Improved consistency during sustained high-performance driving
Wheels
New Super Lightweight Forged Alloy wheel design
Centre lock wheel fixing system
Driver engagement
Revised quad-exit titanium exhaust system
Unique engine mount calibration
Heightened connection between powertrain and driver
Maintains long distance usability
Exhaust and sound
Quad exit titanium exhaust system
Enhanced start up character
Richer and more intense sound at higher engine speeds
Revised induction and exhaust symposer technologies
Twin-turbocharged V8 soundtrack
Driver focused technology
Steering column mounted instrument binnacle
Steering wheel mounted Powertrain and Handling mode controls
McLaren Infotainment System II
McLaren Control Launcher (MCL)
Lightweight carbon fibre centre console
Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen Imagen
