RODIN CARS: 1200HP SUB-700KG TRACK HYPERCAR
RODIN CARS OFFICIALLY ANNOUNCE 1200HP SUB-700KG TRACK HYPERCAR, THE FZERO, IS COMING IN 2023
10/08/2022
Rodin Cars reveal track weapon as their second model since the manufacturer’s inception
Capable of speeds exceeding 360 kph
Built for those looking for the fastest experience available on track, without the limitations of road or racing regulations
1176 horsepower from an all-new 4.0-litre V10 twin-turbo hybrid motor, built and designed from the ground up to Rodin Cars specifications
With a weight of just 698kg wet, the car is expected to have a power-to-weight ratio of 1.662 (PS/kg)
Exclusive ownership opportunity with only 27 units planned for sale
10 August 2022 – Donington Park Circuit, UK: This week, New Zealand performance car manufacturer Rodin Cars has announced that their new track hypercar, The Rodin FZERO, is officially entering production.
Three years after it was first revealed as Rodin’s next venture, the forward-thinking company has released more FZERO production details, including some impressive specs, a release date and the public unveiling of major completed vehicle components at their Donington Park showroom.
Rodin’s most ambitious and eagerly anticipated car yet, the FZERO continues where the previous model, the FZED, left off. Where the purpose of the FZED is to deliver a driver experience aligned with being behind the wheel of a modern Formula One car, the FZERO takes that a leap further, aiming to be the ultimate in track performance, far beyond that of anything seen before.
Building a car without restrictions of road laws or race series regulations, means it can be developed with no limits, allowing for performance that would otherwise be unobtainable. The singular goal of the Rodin FZERO is to be the fastest car around track, without exception.
“The Rodin FZERO is the physical representation of the ultimate heights in vehicle performance. Without the restrictions of building to a set of rules, we are able to make the car lighter, more powerful, and produce significantly more downforce. The only real restrictions we face are the laws of physics, and we have even pushed those to the absolute limit. We look forward to bringing the most intense driving experience conceivable to tracks around the world.”
David Dicker, Founder of Rodin Cars
The Rodin FZERO will be available to customers in a configuration of their choice, allowing them to customize specific aspects of the car based on their driving style and the track on which they will be using it. In addition, Rodin owners receive access to custom racewear services, vehicle storage and delivery, and full driver training at Rodin’s picturesque private race tracks.
Based in New Zealand, David Dicker has crafted Rodin Cars from the ground up, resulting in possibly the most unique and technically advanced vehicle manufacturing facility in the world. Located on a remote 550-hectare property in the South Island, in the shadow of a jagged mountain range, the impressive site, complete with a manufacturing plant, build facility, world-leading 3D printing resources and three test tracks, certainly has the credentials to achieve the company’s vision – to build the fastest car on earth.
27 Rodin FZEROs will be available to buyers, with the first coming off the assembly line in the summer of next year.
FZERO IN DETAIL
CHASSIS, WEIGHT & DIMENSIONS
As the car is made to attack lap times, the emphasis of the FZERO is on weight and airflow aerodynamics. The chassis is constructed from nose to tail of carbon fibre composite, with all components manufactured on site at Rodin Cars.
WEIGHT 698kg
DIMENSIONS
Length: 5500 mm
Width: 2200 mm
Height: 1130mm
Track, Front: 1852 mm
Track, Rear: 1790 mm
Wheelbase: 3000 mm
ENGINE
Designed and developed from the ground up by Rodin Cars and in conjunction with famed engine manufacturer Neil Brown Engineering, the Rodin FZERO is powered by a revolutionary 4.0-litre V10 twin-turbo engine with the assistance of an electric power unit.
At just 132 kg, the engine named the RCTEN, is designed to be the lightest and most compact V10 ever built. A very impressive accomplishment given the engine hasn’t compromised on power, still producing a combined 1176 PS and 1026 Nm of torque. All whilst revving all the way up to 10,000 rpm.
DISPLACEMENT [cc]
4,000cc not created to be bored to 4.5L or 5.0L
MAX ENGINE POWER [PS]@ rpm
1000 @ 9000 rpm
MAX ENGINE TORQUE [Nm]@ rpm
910 @ 7250 rpm
MAX COMBINED POWER [PS]
1176
MAX COMBINED TORQUE [Nm]
1026
MAX ENGINE SPEED [rpm]
10,000 rpm
BORE [mm] x STROKE [mm]
86 mm x 68.8 mm
COMPRESSION RATIO
10:1
FUEL INJECTION
Direct Bosch running at 200 bar
THROTTLE
Bosch drive-by-wire
OVERALL UNIT WEIGHT [kg]
132 kg not including intake and exhaust systems
Hybrid motor power
130kW
DRIVETRAIN
A bespoke gearbox unit manufactured in conjunction with Ricardo UK gives the FZERO 8 gears whilst only adding just under 66kg. The gearbox is encased in a titanium 3D printed case, printed on site in Rodin Cars’ state-of-the-art 3D printing facility.
The differential is hydraulic, and computer controlled.
BRAKES, WHEELS AND TYRES
Weighing just 698kg, the FZERO is ultra-responsive to minimal braking force. However, the car has been equipped with front and rear 380mm PFC Carbon-Carbon brakes, with Titanium callipers (6-piston front and 4-piston rear). The braking system has both ABS and traction control.
Not just used for stopping the car, the brakes also offer regenerative braking from the hybrid system.
The wheels are a bespoke set of 18-inch forged magnesium rims, manufactured in conjunction with OZ Racing and produced to F1 standards. The rims are 18 x 14-inch at the front and 18” x 16-inch at the rear.
The tyres are a race-spec full-slick compound developed by Avon and can be changed depending on weather.
AERODYNAMICS
The massive wings and floor of the FZERO are capable of producing up to 4000kg of downforce, which when compared to the cars weight of just 698kg is impressive.
