caja de cambios del 318i y 318 is son iguales?
cano850
Mensaje por cano850 »
Pues estaría interesado en saber si son iguales la caja de cambios de ambos modelos. Saber se que le valen al mismo motor que se acoplan bien. pero tienen la misma relación de marchas? me refiero a que si son mas cortas o mas largas...
gracias y saludos de antemano
Re: caja de cambios del 318i y 318 is son iguales?
cano850 escribió:Pues estaría interesado en saber si son iguales la caja de cambios de ambos modelos. Saber se que le valen al mismo motor que se acoplan bien. pero tienen la misma relación de marchas? me refiero a que si son mas cortas o mas largas...
¿Has consultado el ETK?
gorri
Mensaje por gorri »
Manual Gearboxes
Four-Speed Five-Speed
316
318i
316 316i 318i
320i 324d
318iS 323i Sport 323i 324td 325e
325i 325iX
325i Sport
1st 3.76 3.72 3.72 3.76 3.83 3.35
2nd 2.04 2.02 2.02 2.33 2.20 2.03
3rd 1.32 1.32 1.61 1.32 1.40 1.36
4th 1.00 1.00 1.00 1.23 1.00 1.00
5th 0.81 0.80 1.00 0.81 0.81
Reverse 4.10 3.45 3.71 4.10 3.46 3.20
Getrag 242 Getrag 240 or 242/5 Getrag 240 Getrag 245 Getrag 260 Getrag 260/5
The M42 engine mates up to the same gearbox used in M40 engines, but is not compatible with earlier M10 gearboxes due to the bolt pattern; you cannot physically fit an M10 gearbox to an M40/M42 engine. Although the M40 and M42 boxes are interchangeable, the input/output shafts are different and so is the propshaft. This means that replacing a 318iS gearbox with the more mundane 318i unit will necessitate a change in prop.
Notice the similar ratios between the Getrag 240 and the Getrag 260/5. This means that for those replacing their M20B20 engine with the more powerful M20B25, Sports performance can be achieving by keeping the original gearbox.
However, don't let parts sellers convince you that the boxes are identical. Getrag gearboxes can be identified by looking for the serial number stamped around the edge of the bell housing. This number should also contain letters, which will identify the following boxes:
Getrag 240 - MN and BMV (M10 carbureted models), BMO, TBCU and BCX (M40 cars and some 318iS)
Getrag 240 - BCO, BCP and BCT - 318iS and E34 518i (pre 1992 overdrive). These boxes are the longer units with the shorter prop.
Getrag 240 - BMS, MB and BMT - 320i models.
Getrag 242 - LF (316 M10 only), MD and BMU (318i M10)
Getrag 242/5 - AY, AW or LG
Getrag 245 - BJ
Getrag 260 - NW, ANB or TNW
Getrag 260/5 - TNN or HM
Esto he encontrado en internet, en un principio monta la gtrag 240, pero depende de que modelo de 240 es lleva diferente desarrollo o no la llevava
Si miras el modelo de la caja verás si puede valer
cano850
Pues si es la misma la del 318i m40 y la de 318is. es igual.
Solo era eso, porque no hace mucho estuve probando un is y hay mucha diferencia a uno i...y las marchas se las comía que daba gusto y va todo original.
Muchas gracias amigo por otra duda resuelta. eres una maquina.
sisu
Mensaje por sisu »
Yo antes cuando tenia el 316, estuve mirando desarrollos, en revistas y tal, y creo que solo variaba la 5a, las demas coincidian..
El que respondiera mejor me imagino que seria mas por el motor que por el cambio, pues incluso llevan el mismo grupo 4.10..
Ex E30 316 Post M10 '88
luigi_82
Mensaje por luigi_82 »
Esque el coche no va igual.el i tiene bajos y el is altos y parece que se alargan las marchas.
elBorja
Mensaje por elBorja »
Te he movido el post al subforo de mecánica que es donde tiene que estar.
